Printed Lines are not the proper thickness or color.
Version(s): 10
To set up a pen's texture, select File > System/Drawing Options > Printer Pen Setup . If your plotter allows you to set up your pens directly from the plotter, then select the "Reset to Plotter Driver". The color assignments as well as pen thickness will be updated according to the driver settings. If, however, your plotter relies on the software, then you may manually set up a color and pen thickness assignment for each available pen.
Once the Pen Setup is complete, select File > System/Drawing Options > Define Pens to Use and assign the appropriate pen number to the printable items in SoftPlan.
Version(s): 11 +
To set up a pen's texture, select File > System/Drawing Options > Pen Setup. If your plotter allows you to set up your pens directly from the plotter, then select the Configure Print Pen Styles button and then "Copy Pen Styles from Plotter". The color assignments as well as pen thickness will be updated according to the driver settings. If, however, your plotter relies on the software, then you may manually set up a color and pen thickness under Configure Print Pen Styles and assign the appropriate pen number to the printable item in the Pen Assignment menu.
