Paint disappears from the screen when I perform a Cleanup or Print.
Version(s): 10, 11
It is likely that the visibility for paint has been turned off. The visibility setting of an item also controls whether it will be printed or not printed. To have paint display and/or print, go to Options > Visible Items and make sure that there is a checkmark beside Paint. Once you return to the Drawing any existing Paint patterns will be shown.
Version(s): 12, 13
It is likely that the visibility for paint has been turned off. Applying paint when the visibility is turned off will result in an attention message “The object you are drawing is not visible. Please go to Options > Visible Items… to change this setting.” If a Cleanup or regeneration of the screen is performed, the paint pattern will disappear. The visibility setting of an item also controls whether it will be printed or not printed. To have paint display and/or print, go to Options > Visible Items and make sure that there is a checkmark beside Paint. Once you return to the Drawing any existing Paint patterns will be shown.
