On a Generated Material Report, some entries are being cut off during the print.
Prior to printing, select Edit > Fit Columns. This will custom fit each column in the report to fit to the longest entry in each respective column. Alternatively, you may also select Edit > Choose Font, and change both the font and size being used or set the page orientation to Landscape under File Page Setup.
