My generated elevation is not displaying any openings? How do I correct this?
By default, SoftPlan does not display any non-bearing walls during the generation of an elevation. Therefore, if
this wall has not been defined as a bearing wall, it will not display itself or any of its openings. To correct,
edit the wall through the File > Drawing Options > Define Wall > Edit and modify the appropriate wall
material definition to include a bearing material.
