My custom defined wall is not showing in the Drawing Wall list. How do I correct this?
You have likely defined the wall at the System Level, which means that this wall will only be implemented on new drawings. To import it into an existing drawing, first sort the newly defined wall to the last slot in the System Wall Definition list. To do so select File > System Options > Define Wall > Sort.Now, within the existing drawing, select File > Drawing Options > Define Wall > Reset to System. Your Drawing wall list will now be overwritten by the System Wall list with the new wall being added as the last available wall.
