Message reads "not enough memory" when plotting a multi drawing.
It is probable that your printer or plotter does not have enough memory to process the incoming information. Some new drivers allow for setup of the print to be processed in the computer. If you are unable to locate this feature on the current driver you are using, try downloading a more up to date driver for your printer.
