Is there any way to save a SoftPlan drawing in another format other than bitmap
(*.bmp)?
Version(s): 10, 11
No. What you will have to do is open the saved bitmap image in another Windows based program and then use Save As
to save that bitmap to the desired format.
Version(s): 12 +
Yes. These versions will also save *jpg files from the Save As Type menu. Otherwise, it will have to be brought
into another Windows based program to change to the desired format.
