Is there a way to control what is printed and what is not?
Version(s): 10, 11, 12
Within the drawing, select Options > Visible Items and remove the checkmark from any item that you do not wish to display, which in turn will also not print.
Version(s): 13 +
Within the drawing, select Options > Visible Items and remove the checkmark from any item that you do not wish to display, which in turn will also not print. Version 13 has additional control of visibility and printing through the use of Layers and Building Options.
