Is there a way to automatically have the program generate with wider shutters?
Version(s): 10, 11
Draw the shutters in elevation with the desired width, and then save into the Shutters library.
Version(s): 12 +
Draw the shutters in elevation with the desired width, and then save into the Shutters Library. An alternative option is available upon editing a Window in the Shutters tab to ‘Adjust width to cover opening’. This will set the shutters wider to accommodate the opening.
