Is there a difference between Enlarge Dimension Numbers and changing the size in Character
Setup?
Yes. The Enlarge Dimension Numbers toggle (found under the Options menu or by selecting Ctrl+Q) is
a visual display only. When the drawing is printed, the size listed in the Drawing Options > Character Setup is
what will be used on the print.
