Is it possible to draw insulation in a general cross section?
Select Draw > Shape > Line > from the status bar, then select the Texture pull down menu, and click on the insulation pattern to use. At the prompt, input the desired thickness followed by the fill increment. Typically a ratio of 2:1 (i.e. thickness of 10”and fill increment of 5”) will give the desired results.
