Is it possible to directly merge a drawing into a multi drawing set?
Version(s): 10, 11, 12
No. You will first need to disassemble the drawing from the multi with which you wish to merge. Upon merging the two drawings together and saving, you can then multi that drawing back into the multi list.
Version(s): 13 +
Yes. You can merge a drawing into a multi drawing set.
