Is it possible to copy a window in plan?
Version(s): 10, 11
An opening cannot be copied in plan. However, by drawing another window you may use the Duplicate command to input the values of another window onto the new window drawn. To do so select Edit > Duplicate > and choose the window whose values you wish to apply to the new window. Select OK to close the Opening Menu, move your cursor to the new window and press the From key. The new window will now take on the properties of the "benchmark" window.
Version(s): 12
An opening can be copied along the same wall it is drawn on. Select Move > Copy > Click on the opening and drag the copy to a new location. Click to place the new opening.
Version(s): 13 +
An opening can be copied along the same wall it is drawn on. Select Move > Copy > Click on the opening and drag the copy to a new location. Click to place the new opening. A copy of an opening to a different wall can be achieved by using the Draw Select command. Select Draw > Select. Click on the desired opening. The status bar will change to Draw the opening. Click to place the new opening to a different wall on the floor plan.
