I have Extracted Framing but my floor joists still do not display. How do I view the joists?
Version(s): 10
Although they may have been extracted, you still need to activate their visibility. To do so, select Material > Type - Structure > which will allow you to double click to place an "x" under Display beside Joist. Close the menu and select the Go button to update.
Version(s): 11, 12
Although they may have been extracted, you still need to activate their visibility. To do so, select Material > Type - Structure > which will allow you to double click to place an "x" under Display beside Floor Joists. Close the menu and select the Go button to update.
Version(s): 13 +
Although they may have been extracted, you still need to activate their visibility. To do so, select Material > Type - Structure > which will allow you to double click to place an "x" under Display beside Floor Joists. Close the menu and select the Regenerate button to update.
