I had symbols on my drawing and now when I open the drawing, they are no longer visible. I
can perform an edit in the area of a symbol and it appears to be there, but is not visible and does not
print.
Version(s): 11, 12
If you recall doing a repeat edit of the symbol type(s) followed later by erasing one of the symbols, you may need
to send the drawing to Technical Support. They will attempt to recover the symbols on the drawing. It will be
necessary for you to draw a copy of the same symbol that is missing somewhere on the drawing before saving the
drawing. Refer to the steps that caused this to occur in your e-mail to Technical Support and attach the affected
drawing.
