I copied my SoftPlan 12 Projects over to SoftPlan13. When I build a 3-Dimension the textures are now missing.
Version 13 has changed the Texture folder locations. There is a SoftView file that was created in Version 12 that has likely been carried over to the same folder as the drawings you are working on. This file will recall the old texture locations which no longer exist. By deleting the 3Dview.tmp file from the Projects folder it will restore the default textures assigned in Version 13 to the model.
