I copied SoftPlan from one system to another, and now I get the message "The SoftPlan key device driver has not been installed on this system." What should I do?
It is recommended that you run a new install of the program so that the Key Driver is properly loaded onto the system and registered in the Windows startup files. Once this is done, both the copied version and the new install will be able to recognize the key. You may then delete the second install and simply use your copied SoftPlan install.
