I can't see my site property in 3D.
Version(s): 10
The property lines need to be a formed polygon in order to create the 3D surface for the grass texture to appear. In Site mode, the command is under Draw > Form Polygon. A left click on each property line is required in a continuous direction (i.e. clockwise) around the perimeter. Right-click at the end to close the polygon.
Version(s): 11
The property lines need to be a formed polygon in order to create the 3D surface for the grass texture to appear. The command is under Edit > Form Polygon. A left click on each property line is required in a continuous direction (i.e. clockwise) around the perimeter. Right-click at the end to close the polygon.
Version(s): 12 +
The property lines need to be a formed polygon in order to create the 3D surface for the grass texture to appear. The command is under Edit > Form Polygon. A left click on each property line is required in a continuous direction (i.e. clockwise) around the perimeter. Right-click at the end to close the polygon. Also ensure that the Site option is turned on under the Extraction Options menu when generating the 3D model. For further instructions, refer to the lesson in the manual for "Creating 3D Surfaces using Form Polygon"
