I am not able to install the second installation disk. I get a message: "The 3D Symbols and Textures DVD
was not found at the specified location. Please choose a different location."
Check that the drive is a DVD drive by looking at the drives faceplate for the letters DVD. Also check that the
correct disc is in the specified drive. If no DVD drive is available on the computer, then the DVD can be installed
across a network from a DVD drive on another computer. If you are unable to install the second installation disk,
the SoftPlan program itself will still open and operate with only the first disk installed. Disc two only contains
textures and symbols to enhance 3D images.
