I am getting the following error when I start SoftPlan: Error 711: "The system clock on
your computer has been incorrectly modified. To correct this problem, you must correct your system clock and
contact SoftPlan Systems for a reset code."
This error is typically caused by moving the key between two systems with different system clock
settings when installing to the system with the earlier time. To correct, determine the time difference between the
systems, remove the key and wait for the time difference or longer to pass before installing the key again. To
avoid this in the future, ensure that the system clocks are matched prior to installing the key on multiple
computers.
