How to generate a Wall Panel Diagram?
From within the Floor Plan, change modes to the Framing mode. In this mode you may assign specific ID numbers to each wall. Once the ID's have been assigned, you may select Draw > Generate > Wall Panels, at which time SoftPlan will create a drawing of the wall framing in elevation, each one labeled according to the ID number assigned.
