How to display my walls in a Solid format for presentation work?
All wall displays are handled from within the Wall Definition. To change the settings select File > System/Drawing Options > Wall Definition > Edit Item > and select a wall type. Each Material Texture Pattern setting may be modified to solid and enabled by double clicking to place an "x" in the column "Texture Visible".
