How should I import drawing files from previous versions of SoftPlan?
Version(s): 10
All old SoftPlan drawings from Version 6 and up have the ability to be brought forward into SoftPlan Version 10. To bring drawings into Version 10, use the older SoftPlan Backup procedure or Tag and Send the drawings to diskette. For instructions, consult your manuals. Once you have the drawings on disk, use Version 10's File » Import » SoftPlan Drawing(s) command.
Version(s): 11 +
All old SoftPlan drawings from Version 8 and up have the ability to be brought forward into SoftPlan Version 11/12/13. To bring drawings from versions 8 and 9 into the current Version, use the older SoftPlan Backup procedure or Tag and Send the drawings to diskette. For instructions, consult your manuals. Once you have the drawings on disk, use the current Version’s File > Import > SoftPlan Drawing(s) command. Since version 10 is also a Windows-based program, this version’s drawings have the ability to be opened in the current Version without using the Import command. It is recommended to copy these drawings into a new folder using the Windows Explorer so that they can be used specifically for the current version. Simply go to File > Open and select the drawing from the new folder.
