How do you move System Information and Configurations from and older version into a new SoftPlan?
Transferring System Options and Library Items to a Newer Version of SoftPlan:
Backing up information from Versions 13 and newer:
  1. Select File  ®  System Options  ® Archive.
  2. Select any of the items that you want to transfer to the new SoftPlan.
  3. Select Backup and you will be given an opportunity to select a location to save the backup information.
Note: If moving information to a different computer using a flash drive or other removable media, uncheck the Use Default box and use the Browse button to select the new location.
Backing up information from Versions 11 and 12:
  1. Select File  ®  System Options  ® Archive ® Backup
  2. Version 12 only: Select the items that you want to transfer to the new SoftPlan.
  3. Select the target drive and hit ok.
Restoring Information to SoftPlan 2012:
  1. Select File ® System Options®System Options ® Archive.
  2. Select the items to restore from the list and select Restore.
  3. Browse to find the saved location of the backup files and follow the on-screen instructions.
Note: A warning message will appear. If you wish to maintain a copy of the existing files, select Maintain Existing Libraries.
