How do I replace the SoftPlan logo at the top of the SoftList material reports with my own?
You can replace the logo in the SoftList Setup. In SoftPlan go to Build > Material List > Setup. Select ‘Report Styles’ and choose a report style. In the ‘Configure Report Style’ menu click on the Appearance tab. In the Add Banner section press on ‘Select Image.’ Browse to the location of your image. Change the Files of type to the type you wish to select. You can use .jpg, .bmp, .tga, .tif, or .png. Select the file name and press Open and OK on the menu. The report should now generate with the logo you selected.
