How do I turn off Opening sizes, Rough Opening sizes and Product codes?
Version(s): 11, 12, 13
To collectively turn off any of the Opening Dimensions, Product codes and / or Rough Opening Sizes select File > Drawing Options > Dimension Options. Uncheck these items in the menu. This will apply to any new openings that you draw. If you need to turn off selective or existing openings, select Edit > Edit Item and select the opening. Select the Display tab, and uncheck the Product Code and / or Size field(s) under Opening Text. Select Edit > Repeat edit (Box) or Repeat Edit (Polygon) and draw a box around additional openings to turn off.
