How do I set up dimension and extension options specific to walls?
To ensure a precise dimension and extension location, set up options for specific walls using the Wall Definition menu: File > System/Drawing Options > Define Wall > Edit. Use the drop-down menu in the Dimension and Extension columns to specify the placement of the wall's specific materials. This setting will override all other dimension options.
