How do I offset the garage slab separately from the basement slab?
Version(s): 10, 11, 12
After you have traced in the garage slab, select Edit > Edit Item and select the Slab. A Slab menu will be opened. Before you can assign a new Offset you must first assign a new Level number to this slab. By default, all floor system will begin with an assignment of 1, meaning that any changes made to this slab will affect all slabs which also have a level number of 1. To change only this slab's properties, change the level number from 1 to 2, then input the desired offset.
Version(s): 13
After you have traced in the garage slab, select Edit > Edit Item and select the Slab. A Slab menu will be opened. Version 13 will automatically assign different Level numbers to each floor system component. Input the desired offset for the garage slab.
