How do I make the Opening Frame the full width of the wall?
To make the Opening Frame the full thickness of the wall, select File > System / Drawing Options > Material Dimensions > Opening Options. Change the value for Frame Width to 0”. The Opening Frame will then extend through the wall without needing to change the Opening Offset. Opening offset will have no effect.
