How do I know what sequence numbers are in use with SoftList?
Select Build > Material List > Setup. Select Report Styles > Listing Format to review what groupings of
numbers have been reserved (i.e. materials dealing with Framing need to be assigned a number between 20 000 and 29
999). While in the Edit of the material, click on the Accounting button and click on the Review button to see the
same list. Note: that the sequence numbers can only be modified in the Listing Format.
