How do I insert a logo into SoftPlan?
Version(s): 10, 11
Prior to version 12, SoftPlan could import Dxf files only. Generally the images used for logos are not in this
format.
Version(s): 12 +
File types that can be imported into SoftPlan are DXF or DWG for drawing type files. BMP, JPG or TGA files are
image files that can also be imported. To import a logo in a DXF or DWG file type, click on File, Import, DWG/DXF
and click on the drawing surface. You will then be prompted to browse to the location of the file you wish to
import. For more information, see page 596 in the Version 12 Learning SoftPlan manual, Importing DXF and DWG
Drawings. To import a logo in a BMP, JPG or TGA format, click on File, Import, Image and a window will open
prompting you for the location of the image. Browse to the location where the image is stored, highlight it and
click the Open button. Place your cursor in the approximate area you would like the image to appear, click your
mouse and an expandable box will start, adjust the size of the box to the area you want the image to occupy and
left click your mouse.
