How do I get one panel of a double door fixed?
Version(s): 10
Edit Item the double door in floor plan which will open a menu titled Opening. Select Options to expand the Opening menu and change the menu item Operate to indicate each Door Leaf's swing. For fixed, the operative would be "N".
Version(s): 11, 12, 13
Use Edit Item to edit the double door in floor plan. Select the Display tab. You can specify the fixed panel under Hinge side. The operative will be “N” to indicate fixed. The Hinge side is read as if viewing the opening from the exterior. Use ‘L’ to indicate Left and ‘R’ to indicate Right hinge sides.
