How do I get extensions to pull from the outside of a stud?
To ensure a precise extension location, set up extension options for specific walls using the Wall
Definition menu: File > System/Drawing Options > Define Wall > Edit. Use the drop-down menu in the
Extension column to specify ‘Outside’ for the Stud material. The placement of the extension will override other
dimension options.
