How do I generate a side elevation from the inside of a “U’ shaped house?
Add a Section Line (Build > Section Line) running through the center of the “U’ shaped building pointing in the appropriate direction. Generate a Cross Section of the building and check Background (Build > Cross Section > check Background in the Section Dialog > OK).
