How do I draw two separate windows stacked one above the other with a gap between them?
Draw the two openings beside each other on the wall. If the wall is not long enough, you may have to use the
Adjust command to extend the length temporarily so you can fit the windows in the wall. Edit the opening that will
be on top and increase its offset to set it above the opening that will be on the bottom. Use the move command to
place it over the other opening. Use Profile mode to make sure the openings are in the correct location.
