How do I draw an arched opening in a wall?
Version(s): 10
Draw an opening on a wall. Edit > Edit Item the opening. From the type menu, drop down to select Dash Arch/
Solid Arch and set the size as necessary.
Version(s): 11, 12, 13
Select Draw > Opening > Arch and select the desired style. Move your cursor onto the wall and select the From
key where the center of the opening should be placed. As shipped, the opening will be 3’ wide. Edit the opening
with Edit Item, uncheck the Product Code checkbox and modify the size as necessary.
