How do I draw a wall of half block or half concrete and half frame?
This is accomplished by defining a new wall through the Wall Definition. Select File > System Options > Define Wall > Edit. Highlight on one of the predefined framed walls and select Save As. Type in the desired name and press enter. From the Wall/Beam Selection list, click on the new wall for editing.
You will first want to edit each of the framed wall's material heights and vertical start (i.e., on an 8'-0" wall height, the siding height could be 4'-0" with a vertical start of 4'-0"). Once all materials have been adjusted accordingly, select ‘Add Material’ which will place an Adobe Brick directly below the last material on the inside (drywall).
Change this material to Concrete A, Width = 9" and Height = 48". The horizontal start of the Concrete would be the measurement from the outside of the siding above to the outside edge of the concrete.
