How do I draw a thicker line?
Upon selecting Draw > Shape > Line, you will be able to move your cursor to the status bar at the top of the screen and change the texture. Click on the arrow to open available textures and select the thicker black texture. On selection of this, you will be prompted to input the thickness.
If the line is already drawn, Edit > Edit Item the line, open the texture box and select the thick black line texture. You will then be able to input a thickness for the line in the width field.
