How do I draw a rectangular transom window above another opening without a gap between them?
Version(s): 10, 11, 12
The Add Opening Component feature can be used to create an opening with multiple units. This can be found under File > System Library. In the Library section of the menu, select Openings from the Type field. Highlight the Library you want to add the new opening to. Select the Add button from the Symbol section of the menu. The Add new Opening menu displays allowing you to configure your new opening.
Version(s): 13 +
Draw one window and then edit it. Click the Add Transom button. A new window will be placed directly on top of the existing one, at this time you can change the height of the new opening but the width will match the width of the original window.
