How do I display Opening sizes, Rough Opening sizes and Product codes?
Go to File > Drawing Options > Dimension Options. Check the items you want to display. This will apply to any new openings that you draw. To display any of these items for selective or existing openings select Edit > Edit Item and select the opening. Select the Display tab, and under Opening Text check the items you want to display. To display these items on additional openings, select Edit > Repeat Edit (Box) or Repeat Edit (Polygon) and draw a box or polygon around additional openings to turn on the display.
Note: In order to turn on the Product code for openings, you must have Product code checked under the Plan tab as well as the Display tab (Edit > Edit item check Product code under the Plan tab and Display tab).
