How do I create an exterior concrete landing?
Version(s): 10
In Floor Joist mode, draw the concrete slab. In order to offset this floor system up, you will need to edit the
slab and assign a new level number to the slab. Edit the slabs offset keeping in mind that the offset is to the
bottom of slab.
Version(s): 11, 12
In Floor System mode, draw the concrete slab. In order to offset this floor system up, you will need to edit the
bottom of slab.
Version(s): 13 +
slab. Version 13 automatically assigns a different Level number, so simply enter the offset for the slab. Keep in
mind that the offset is to the bottom of slab.
