How do I create a brick ledge in a slab?
Version(s): 11, 12
Draw a Structural Slab in Floor System mode. To create the brick ledge, select Edit Item and click on the slab edge. Select the option ‘Recess Wall Above’ and enter the required depth.
Version(s): 13 +
Draw a Structural Slab in Floor System mode. To create the brick ledge, select Edit Item and click on the slab edge. Select the option ‘Recess Wall Above’ and enter the required depth. In addition, select ‘Recess Surface Only’ which will create the drop down for the brick surface of the wall from the outer edge of the slab.
