How do I control the Opening Position within a wall?
This is controlled under the Wall Definition. Select File > System Options / Drawing options > Define Wall > Edit. Select the wall to change under the Wall / Beam selection menu. Under Options, change the Opening Offset value. This reflects the distance measured from the inside of the wall to the inside of the openings placed on the wall.
