How do I combine several drawings together for printing?
The Multi Drawing feature will allow for multiple drawings to be assembled for such purposes. It is
recommended to combine the drawings onto a base sheet. Select File > New > Drawing. Select File > Save As.
Name the drawing (i.e. Sheet1). Select File > Multi Drawing. Check the Enable box. The currently opened drawing
lists under the heading Current Drawings. On the left is a list of Available Drawings which may be Added to the
Current list. Simply click on the available drawing then Add it to the Current list. Select OK and both drawings
will display together on the screen, although they are still considered two distinct drawings. When changes are
made either in the independent drawing or in the Multi drawing it will reflect both places.Also note that the drop
down menu with the drawing list will now be prefaced with ‘Multi’. Whichever one of the drawings is listed here is
the only drawing which may be worked on. At any time, the Multi may be canceled by taking the checkmark off of the
Enable field.
