How do I change the walls to display with a shaded texture as well as print the walls with this shade?
The screen display and the printed display for walls are controlled separately within SoftPlan. To change the display on screen, select File > System/ Drawing Options > Define Wall > Edit > and select the wall to change. Each material will have a setting for the Texture Visible, Texture Pattern, and Texture Color. These items will control the display of the wall on screen. Turn on the Texture Visible for the materials to be shaded. Then select the solid Texture pattern and assign a gray Texture color. The preview of the wall will update to show you what it will look like in plan view. The wall setting, for printing purposes, is controlled by the Texture Pen in the same section of the Wall Definition menu. The pen number that is selected relates to the Pen Setup. Select File > System/ Drawing Options > Pen Setup. Click on Configure Print Pen Styles. Assign a gray shade to the corresponding pen number. The wall will print shaded.
