How do I change the plan view of a wall to print with a grey tone fill?
Version(s): 10
Your printer driver will refer to this as a gray scale. If your printer allows for gray scaling go to File > System/Drawing Options > Define wall > Edit > select the wall in question > scroll to the far right > change Texture pattern for a material(s) to solid and change the Texture pen of that item to pen 16. Click OK.
Then go to File > System/Drawing Options > Printer Pen Setup > double-click on the black box next to number 16 and select a grey color. Click OK.
Version(s): 11
Then go to File > System/Drawing Options > Pen Setup > Configure Print Pen Styles > double-click on the black box next to number 16 and select a grey color. Click OK.
Version(s): 12 +
Your printer driver will refer to this as a gray scale. If your printer allows for gray scaling go to File > System/Drawing Options > Define wall > Edit > select the wall in question > scroll to the far right > change Texture pattern for a material(s) to solid and change the Texture pen of that item to pen 16. Click OK. The default print pen color for pen 16 is gray.
