How do I change the orientation of a Joist Poly?
Version(s): 10, 11
The reference edge for a Joist Poly appears with an "XX." To change the direction of joists, use the Edit Item
command. Click the edge you want the joists to run parallel to and check the item Reference Edge.
Version(s): 12 +
The reference edge for a Joist Poly is indicated with a solid green triangle. To change the direction of joists,
use the Edit Item command. Click the edge you want the joists to run parallel to and check the item Reference
Edge.
