How do I add texture to the elevation?
First, the elevation must be generated and saved. Once saved, open the elevation drawing in SoftPlan. Then select
Draw > Paint > which will open a menu allowing you to select a paint pattern. To add a pattern, click on the
name. This will give you a preview of the paint pattern. Then move your cursor onto the drawing screen and click
where you would like to place it. The paint will then fill the enclosed area with the paint pattern.
