How do I add notes to a floor joist layout?
Version(s): 10
Because floor joists are a part of the floor plan, you cannot add notes until you save the joist plan as a drawing. To do this, select Generate Drawing from the Joist mode Draw menu. After you save, you can add notes (and dimensions), to the drawing.
Version(s): 11 +
Because floor joists are a part of the floor plan, you cannot add notes until you save the joist plan as a drawing. To do this, select Generate Drawing from the Floor System mode Draw menu. After you save, you can add notes (and dimensions), to the drawing.
