How can I put all of my elevations on one sheet for plotting?
Version(s): 10, 11, 12,
It is recommended that you use the Multi Drawing Feature that is accessible from the File menu. To assemble the
drawings, first create and save a ‘Base’ blank drawing to which the other drawings can be added, then select File
> Multi Drawing. On the available menu place a checkmark next to Enable, which will now allow access to the
Available Drawings and Current Drawings listings.
The opened drawing will be listed under the Current Drawings and is considered the base drawing. From the Available
Drawing list you may then select the elevation drawings. Use the Add button to have the drawings transferred to the
Current Drawings list.
When placing the drawing on screen relative to the Base Drawing, select the Position Button in the lower right
which will allow you to move the Add-On drawing in the desired location. Left click to place the drawing. Repeat
the process for the other drawings that you want to add.
Version(s): 13 +
> Multi Drawing > Multi Drawing. On the available menu place a checkmark next to Enable, which will now allow
access to the Available Drawings and Current Drawings listings.
